Salt Water
otobmark
NC
When working around a marine environment everything gets coated with a salty haze. Is it a good idea to freshwater rinse off HT’s? On new radios I guess it’s ok to trust the sealing but some of the old cashe radios who knows?
MTS2000des
5B2_BEE00 Czar
MSI and other manufacturers generally say one should not submerge a portable in any liquid unless one is vacuum testing it. Most cleaning instructions call for a solution of dish detergent and water, and wiped down with a cloth/towel and if needed, use an old tooth brush to dislodge dirt that doesn't wipe off.
MiCon
Mike
central AZ
What he said.
Also, not being sure how your radios are being use, but covering them when not in use will cut down on how much and how often you get the coating build-up.
otobmark
NC
So don’t run them through the dishwasher?🤔. Killjoy
tvengr
Well Known Member
Baltimore County, MD
Read the following at your own risk! Please don't try this:
Years ago, I saw a story in an electronics magazine about a Hallicrafters receiver in a boat which quit working due to salt buildup. The writer put his radio in a bathtub full of water overnight and allowed it to dry thoroughly. The radio worked perfectly. That is an easy way to damage speaker cones and cause rust and other corrosion.
otobmark
NC
I had an electronics company and we ran our assembled boards through a glorified dishwasher to remove flux from wave soldering.
