same feature as pro 96?
fryertuck
burks falls ontario
PRO-96 automatically calculates Motorola and APCO-25 trunking system voice
channel frequencies while decoding the control channel. This eliminates the need to
enter all the Motorola system frequencies.
So will the 396 do this?
What a great feature if it does plus close call WoW
TY
FT
JonHanson
Gilbert, Arizona
I noticed in the peliminary user's manual for the 396 that this function defaults to off. Meaning you need to go into the menu system and change the Motorola tunk settings to control channel only. This default may be different when the radio is actually released, though. I would think the default would be control channel only programming for Motorola systems.
kikito
North Pole, Alaska
You will be in the menus while setting up a system anyway, so it's not that big of a deal. To activate the CC only, it might be a few clicks away from where you set up the frequencies.
AZScanner
Somewhere in this room. Right now, you're very col
Actually (assuming it will work like a 796 does) you will want to set CC only mode to OFF. If you turn it on, you will confuse the scanner and miss comm's.
You also will not need to enter any voice channels. The scanner finds them automatically. Entering the voice channels will only do 2 things, both bad: Take up space and waste time finding the active CC.
-AZ
UPMan
In Memoriam
Arlington, TX
Thread confusion alert. Other than the immediately preceeding post, CC is referring to Control Channel Only mode (not Close Call).
Al42
Long Island, NY, USA
So what's the definitive answer? Do we program only the CCs and leave CC-only mode off? (Why is there even a non-CC-only mode for Motorola?)
And any decision on whether those of us who have already ordered the 396 can get a jump on downloading the software, so that we can be set up when the scanner comes?
BTW, since I've never said it before, a huge thank you for everything you do for us hobbyists here and on other BBSs, lists, etc.
UPMan
In Memoriam
Arlington, TX
If you want to only program CC's, you must turn on CC-only.
Hoping, but not promising, to have UASD on the web site prior to release. Working on revising the help file, now.
Paul
Al42
You're doing the help file after the device specs are nailed down? Wow! There's hope for the human species yet. :)
