hello iwant to try to hear weekly test, i have 3 diifrent counties programmed in. know when i go to weather op- i programmed in my 3 countys with the fips codes. now where do i go from here i see weather scan which i think is just regular then i see weather alert. do i use weather alert i think i do, next isee alert only- then the 3 countrys i put in then i see same 4 same5 and all fips . which one do i use should it be all fips so it would scan all 3 countrys, i think this is right. it not can someone help me on this, if i just want to do 1 individial would i just press 1 of the 3 to just scan 1 by itself. anyhelp on this thanks im using the bcd-996t thanks again
