San Antonio juvenile detention center Mission Rd San Antonio TX
hiegtx
Dallas, TX
Anyone one know what frequency or what system the CO’s radios use at the juvenile detention center?
I'm nowhere near enough to confirm the data below.
On the old EDACs system, there were 3 talkgroups apparently associated with Juvenile Detention.
Most of the talkgroups from the old system appear to add 38000 to the EDACS TGID, to generate the talkgroup on the new system.
If that pattern is applicable, then TGIDs 39099, 39199,ans 39101 should be the talkgroups on the newer system.
Try these & see if that pattern is correct:
From the AARRS system:
SA_tx_88116
Rather listen than to stream
Cibolo, Texas
I believe they moved on to talkgroup 39102 on AARRS because it’s labeled mission DET given that the detention center is on mission rd I believe this is where they are those talkgroups that hiegtx posted look like they belong to the Bexar County jail, now all I have to do is wait to get an SDS100.
hiegtx
Dallas, TX
Why would I have to be close?
Look at the license. There is no repeater. Just a "fixed location" (like a dedicated 'base station or control point, using another handheld or mobile radio), and mobiles, which likely would be handheld units. That's not going to put out a strong signal that could be heard some distance away. More likely, your usable range would be a mile or two.
NC5267
San Antonio
I have not heard them on the AARRS system. Only the main jail and the annex downtown I have seen detention center-wise, and they are partially encrypted.
Mission Rd Juvinelle has been on 155.220 for many years, I haven't been in that area in a few years. That license is active until 2033. I picked them up in the downtown area, but they were pretty broken up, but could copy transmissions. That license has 155.220 with an FB2, which means it is a repeater, just a low-power one with only 25 ERP. 150.790 is the input.
rattlerbb01
TX/LA Database Admin
Boerne, Texas
Heck I’m coming in from Pleasanton today, I’ll drive by and see if 155.220 pops up.
