San Bernardino County
brandon
SoCal
Here are the ones I have in my scanner
151.1450 / PL 167.0 - 1-FIRE-1 Patch
151.1450 / PL 103.5 - 6-FIRE-2 Patch
159.1200 / PL 167.9 - 8-FIRE-1 Patch
154.0250 / PL 167.9 - Ontario (dispatcher only)
Don't know if this is a patch or not but 154.205 you can hear Victorville FD.
Hopefully they keep these VHF patches around, especially 151.145! Also I've seen 151.145 / PL 110.9 listed as 4-FIRE-1 but I'm too far to hear it. Maybe someone can confirm it.
I've also seen 154.190 listed as Big Bear FD is that even used?
disp10
Officially called "County 1", 151.145 is patched to 6-Fire-1, not 6-Fire-2.
RobertW1
Burbank, CA
FireMan16 said:
Is there any for the 800 freq
Yes there are. Wrightwood uses conventional 800 MHz frequencies for both San Bernardino County Sheriffs and Fire since the terrain doesn't allow for very good "trunking".
867.1875 Wrightwood Conventional Law (Patch to 1-DC-1)
867.8625 Wrightwood Conventional Fire (Patch to 1-FIRE-1)
867.6125 Wrightwood Conventional Patch to Hospital
Station 101 (Wrightwood) transmits on 800MHz "conventional" frequencies to Frost Peak (above Mountain High) which only uses conventional frequencies. Frost and Quartzite (in the high desert) are linked via VHF and that is how Station 101 enters the 800 MHz 1-Fire-1 trunked system. The same is true when San Bernardino County Sheriffs are in Wrightwood. They link into the 1-DC-1 System via Coventional 800 MHz hitting Frost Peak.
Fire's System 1 "Victorville" group (1-FIRE-1) is patched into County's VHF County 1 (151.145) and when handling runs in the Cajon Pass, Wrightwood switches to System 8 "Mountain" (8-FIRE-1) which is patched into County 2 (159.120).
For Wrightwood Area Freqs:
Wrightwood Scanner Frequencies
Here are the "Conventional 800 MHz" frequencies used in San Bernardino County:
866.8625 D-LAW-1 (Trona / Afton Cyn / Iron Mtn)
867.1875 D-LAW-2 (Goffs Butte / Wrightwood / Central City Mall)
866.1375 D-LAW-3 (Havasu / Baker / Lytle)
866.6375 D-LAW-4 (Parker / Mountain Pass / Ridge)
868.9375 D-FIRE-1 (Trona / Afton Cyn / Iron Mtn / Forest Falls)
867.8625 D-FIRE-2 (Goffs Butte / Wrightwood / Central City Mall)
868.1375 D-FIRE-3 (Havasu / Baker / Lytle)
868.4125 D-FIRE-4 (Parker / Mountain Pass / Ridge)
867.9125 D-GOVT-1 (Trona / Afton Cyn / Iron Mtn)
867.6125 D-GOVT-2 (Goffs Butte / Wrightwood / Central City Mall)
867.1375 D-GOVT-3 (Havasu / Baker / Randsburg)
867.4125 D-GOVT-4 (Parker / Mountain Pass)
RobertW1
Burbank, CA
Victorville and Big Bear FDs are part of the "Regional Fire Protection Authority" or DESCOMM (Desert Communications). They have their own trunked system using EDACS Analog 800 MHz frequencies. The VHF frequencies mentioned, 154.205 (Grey) and 154.190 (Green) are Dispatch simulcast frequencies.
jeff2233
So CA
I think they are still using 154.190 as a dispatch simulcast of the 800 system in the valley areas. SB City Fire shows 453.3875 as their simulcast freq.
disp10
154.190 is no longer used as a dispatch simulcast in the valley. City Fire no longer uses 453.3875 for simulcast.
