It’s as if there using analog radios that’s than converts to p25. It’s really bad. I have recordings from the System.
What’s the story with this system being so bad but used heavily
You can think of the 700 MHz and 800 MHz as one system because they share a common zone controller / ASTRO system core (if it’s still called that). The talkgroup numbers on the 700 MHz system are the 800 MHz talkgroups divided by 16, because they’re all leading back to the same computer server and the two systems just have two different formats.
The back story is that the analog 800 MHz Motorola SmartZone system used to be the only system.
Motorola stopped supporting the old analog Astro core and they needed to upgrade to the P25 core, but they were able to upgrade the system core backbone only and use hardware at each site to make the system backwards compatible with analog SmartZone operation. Both the dispatchers and mobile units sounded great, but one day when they flipped the switch on the core changeover the mobiles (who were analog) continued to sound great but the dispatchers all started sounding robotic and digital (because they were talking through the new P25 core and then being converted back to analog).
Fast forward many years and they started building out the 700 MHz P25 system using the same Astro core and gradually migrating users over (starting with the garbage trucks lol), and now we’re to the point where most if not all of the police and fire radios are converted over to the 700 MHz P25 system. Therefore what you’re hearing on the 800 MHz system is both the dispatcher and mobiles on the P25 side being converted back to analog, and yes it sucks.
There are a few analog stragglers on 800 MHz I think including random public works, water and sewer department type stuff, and yes they still sound good!
