San Diego County 800mhz traffic
EyeInSkyPix
As of yesterday, August 16th, I'm no longer hearing any San Diego County 800mhz traffic. Does anyone know if any changes have been made there? Is it encrypted now or has it moved to 700Mhz. Is there some other change I have not heard about.
I'm hoping I just screwed up something on my scanner, I'd hate to lose the ability to hear our local LE.
zz0468
Banned
Southern California is finally rebanding. Check 15.000 MHz lower for everything.
celbaseman
Poway, CA
15 MHz lower will not work with the North Cell, they have completely new control channels.
zz0468
Banned
Well, that happens sometimes. 15 mhz is a good place to start, but in some specific situations, that doesn't work.
celbaseman
Poway, CA
North Cell
The new control channels are:
854.8125, 855.8625, 855.1125, and 856.9125.
EyeInSkyPix
Thanks cellbaseman! It is scanning and stopping on channels now but it is only picking up the carrier, no voice.
I have a Whistler TRX-1, Any thoughts?
Anderegg
Enter text in this field
San Diego
For Whistler, just change from Splinter to Custom...the DEFAULT values in Custom (hit edit to view) work for fully rebanded straight out of the box.
For Uniden, enter the new control channels (853.4125 south, 856.9125 north, add the secondary CC's also) and change the system/site type from Splinter to Motorola Type II Standard.
Paul
EyeInSkyPix
Thanks again celbaseman! It's scanning correctly and picking up voice now.
Anderegg, on my Whistler TRX-1 I did have to enter the new control channels as well as make the changes you suggested, changing Splinter to Custom.
Glad to be listening to Station M again ;)
Is there a schedule to reband the other cells, if so, where can I find the timing and new frequencies so I know what changes to make at that time.
Anderegg
San Diego
The main North, South, East, Northeast sites have all completed rebanding.
Paul
scottyhetzel
Palm Springs Area / OrCo
Paul
You forgot to add... check mark control channel only.
Anderegg
San Diego
I believe he was referring to the Uniden setup.
Paul
d119
Patch & Channels Clear...
EM1's guest house.
So there isn't any question or confusion, the entire San Diego - Imperial Regional Communications System has been re-banded. This includes all simulcast cells, intellirepeater sites, and conventional mutual aid systems.
It's all done, folks. At this point the only major 800MHz system in San Diego County remaining to be re-banded is the City of San Diego 800MHz system.
f40ph
CC actual
Largest County, USA
It is working fine without a check mark. But, if I wanted to add the checkmark, where would I find that in the EZ Scan app?
If you have the latest firmware update, I don't think you can "not" use control channel only. I lost that option when I updated.
K3OZO
San Diego, CA
Correct me if I'm wrong, but several of the IR sites, including most of the Imperial County sites don't seem to have been updated in the database here post-rebanding. I don't know if just deleting 15 MHz from the listed frequencies is correct in all cases.
d119
EM1's guest house.
Believe me when I say that the RCS is completely done. All of it. Imperial and San Diego counties.
K6CDO
Hanover Co. VA
The database corrections are in progress.
