Wonder what talk group or channel the RCS uses to reprogram radios or does each department have their own assigned
channel?
channel?
I agree. I just received a very large codeplug from radio management via WIFI in under 2 minutes.OTAP/POP25 utilizes the standard packet data system built into the ASTRO network (hence IV&D, integrated voice and data). Data calls are a separate thing and indicated specifically in the P25 CAI. It's a convoluted side of the infrastructure in how it all works but basically a radio will do a context activation after registering on the system; this process is similar to how a computer requests an IP address when it isn't assigned a fixed/static address. There's an assortment of infrastructure that makes this all happen (GGSN, PDR/PDG, Border Router) so that the system keeps track of the the radio network so the data calls can be sent efficiently. The device called the border router is the last router before the IP data that a subscriber initiates is introduced to the network where your data services are (so KMF, Radio Management, AVL, etc). To add to that, services such as AVL and OTAP can use encrypted data via an added device in the packet data network. The KMF is natively encrypted so these other services rely on a packet data encryption gateway to handle the other packet data services. This packet data network is often connected to the customer's private network where their CAD system resides to there's inter-operation between CAD and subscriber database (UCS aka Provisioning Manager) (for example).
From a scanner perspective you'll have no idea this is going on unless you monitor in conventional. Data calls don't utilize groups, but you will see radio IDs during the calls. Channels by default can handle both voice and data, with voice taking priority and you can enable the ability to pre-empt a data call for voice if the system loads up. Voice and data can be an and/or if you so want to dedicate a channel for data (see enhanced below). Calls are sequenced like people lining up at a bank.
Then there also an enhanced data format (you'll see it in a flashcode) that's typically associated with AVL and adds abilities like the ability to send location on PTT. When AVL is used on a system you'll see quite a lot of data calls. There are a lot of options as far as location goes, and some can send data often.
The smart way to do OTAP is to sync over WIFI to the radio management server and get the programming jobs that way.
