San Diego Sheriff Unit IDs?
inigo88
California DB Admin
San Diego, CA
Hey guys,
I've seen the SD Sheriff unit ID list on scandiego (as well as the one in the scannerstuff Southern California Frequency Directory, which is about the same) available here:
SCANDIEGO.COM SDSO UNITS
However it doesn't quite match what I'm hearing in real life. According to that list the first two digits are the Service Area, followed by a letter denoting the type of unit, another letter denoting a higher rank (if applicable) and a number between 1 and 3 for the shift. A couple problems:
1.) Not all patrol units use the "Paul" unit type. Some use it and some drop it. For example "31 Paul 11" vs. "32 - 5" or "32 - 3." (The latter being pronounced "Thirty two three," much like a CHP unit ID which has no intermediate letter.) It seems like this could either be really poor radio discipline, with both patrol deputies and dispatchers using or dropping the "Paul" in the unit ID interchangeably... or there is a difference between regular units with no letter and the units with a "Paul" in the unit ID. Anyone know the difference?
2.) The last "shift" number is often greater than 3 (ex. 31P11, 32-5, 32-7, etc.) which makes me think it's not a "shift" at all, but rather a beat number within that service area prefix. Considering cities like Vista (31), San Marcos (91), Lemon Grove (61) etc, they are far too large to only have one deputy on duty per shift, and they are far too large to give that deputy free reign through the entire service area. So the logical conclusion would be to have multiple deputies on duty in those areas each shift, and break those large service areas into smaller beats. I am guessing that beat number is the last digit of the unit ID, and not the shift.
It's clear that the scandiego SDSD unit breakdown is not entirely accurate. Can anyone familiar with the department help me fill in the blanks?
K6CDO
Hanover Co. VA
Some data on both lists is out of date, although the format for most units is correct: Area-Type-Rank-Beat-Shift.
Discipline isn't that tight: many units will "shorthand" their call signs. As an example listening to VTAD right now, 32P3C just arrived at a call saying "3-2-3 10-97." In some cases where two units are working on a call, one unit will voice the status changes by combining the two unit IDs (giving as an example "31P37"),
Command Staff (and selected support staff) just use "Unit" followed by one or two digits.
The Wireless Services staff uses "Radar" with the numeric ID. RACES members when on the system use "RACES" plus their numeric ID.
inigo88
California DB Admin
San Diego, CA
Aha that makes much more sense! So the shifts are broken into an A/B/C shift and then usually not voiced? I got especially confused because dispatchers will often voice the same shorthand unit ID the deputy gives. For example:
Deputy 1: "31 Paul 1, 10-97"
Station M: "10-4 31 Paul 1, 97."
Deputy 2: "31-3, 10-8."
Station M: "31-3, 10-8."
Thus, I started wondering if there was something different about the Paul units then the shorthand ones. Both the scandiego and scannerstuff unit ID lists completely missed beat and listed "Area-Type-Rank-Shift" instead of the proper "Area-Type-Rank-Beat-Shift" which makes much more sense.
Finally, I think that's really interesting how they shorthand combine two unit IDs into one. I've never heard another department do it that way, most would say "31 Paul 3 and Paul 7" in lieu of "31P37."
Now to start paying attention to addresses and figure out which beat is which. :)
Thanks again!
carlt
SD County, CA
I believe that the shorthand of the Paul designator is because "most" of the radio traffic on Dispatch is with those units, so unless otherwise voiced, the unit is a patrol unit. I also usually only hear the shift letter when units overlap in the field. (CHP does the same.)
Also, the CAD shows all units logged on, so if Dispatch doesn't know who someone is by their designator, they will clairfy.
SDWolfman
San Diego County, CA
Additionally, every time a unit goes on shift, they log/link their portable radio, vehicle radio, and vehicle computer into CAD with their call sign for that shift and personnel ID. Every time they key up a radio, this information shows up on the dispatcher's CAD screen.
dwilde94
The last number in the callsign is a beat.
I know that in the SNTD area (50Px), there are 4 beats in the city (51) and 4 in the county (50). And then there's alpine (52), which im not exactly sure how many beats are there.
If the last number is odd, then its a day/nights shift. If its even, then its a swing shift.
To break it down:
51P1C: 5-SNTD 1-Santee City P-Patrol 1-Beat 1 C-Nights
mike619
On 33872 and 29952 on RCS I hear SDSO units with the callsign Henry and John I.E John 134 do you know what they do?
dwilde94
With SDSO, H is for homicide and J is for juvenile detectives. But those TGID's are for county probation command and inquiry, so I'm not sure about those.
musician2111
Those definitely sound like County Probation Units. I am not sure how their call signs work but it is possible they were doing compliance checks at peoples' places of work and home.
IBScan
Imperial Beach
My understanding of it to be
Station - Unit[Rank] - Beat - Shift
Ex: 71 Paul 1 Charles (71P1C as it shows in CAD) Is Imperial Beach Unit - Patrol - Beat 701 - Third Shift.
Ranks: 70 Paul Sam [Charles] is Station 70's Patrol Sgt, Third shift. Only time I hear ranks using the shift ID is when there are multiple logged on. ex: 70 Paul Sam Adam and 70 Paul Sam Charles are logged on.
When I did my ride along with them. There was a map of the city with beat numbers on a grid 701, 702, etc
So for station 70 Imperial beach
70 For Bonita
71 For city of IB units
The unit 'Charles' Ex 70 Charles 1 when not denoting a Capt. Scan Diego's list denoted them as Communications.
I hear them on primary as if routine patrol unit.
But you can hear them on LE South Tac 2,3 doing what sounds like RATT.
musician2111
When you hear a Charles unit such as 70 Charles 2, they are part of a COPPS unit or they are a group of deputies doing a special detail/assignment and are designating themselves as that so as to not confuse dispatch. Normally they have a particular mission or function and are not available for routine patrol calls.
If you were to hear someone say 60 Charles without a number afterwards, which would look like 60C, then that is THE Captain (there is only one) of that particular station.
The use of the word "beat" has two meanings. One is proper and the other is when it is used as slang. Technically speaking, a beat is a specific geographical area used for crime statistic purposes and is how ARJIS compiles this information for public and law enforcement use. Since the OP is using Imperial Beach, a beat is designated as 701,702,703 etc. However, Deputies use the term "beat" in a slang fashion to refer to an area that belongs to a particular car assignment such as the 70P1 beat. The 70P1 beat/car might be assigned an area comprised of many beats such as 701-705 for example. Technically speaking this is supposed to be referred to as the 70P1 Car or the 70P1 Sector. However the use of the word car and sector in this fashion haven't been used for probably 20 years and have fallen out of remembrance by many current employees. This is why when we hear the term beat or beat unit the general public can be confused. Like all language, it depends on the context of the sentence and the topic of the conversation.
