San Jose FD freqs ????
zerg901
yup
KMH603 shows a repeater on 150.805 and it also shows 155.13 as mobiles only
The only San Jose license on 155.13 (KMH603) shows mobiles only - ULS License - Public Safety Pool, Conventional License - KMH603 - SAN JOSE, CITY OF - Frequencies Summary
same for 154.31
san jose does not show an active license on 151.04
KYW990 ULS License - Public Safety Pool, Conventional License - KYW990 - SAN JOSE, CITY OF - Frequencies Summary only shows the freqs 154.115 153.98 155.82 155.88
The principal incongruitys exist around 150.775 150.805 155.13 but also 154.31 154.43 harumph
(I suspect they are moving to 700T soon but it would be nice to accurately document the VHF freqs at this time)
back in 2012 I was trying to figure this out also - https://forums.radioreference.com/threads/new-san-jose-fire-freq-found.185818/page-5#post-1815819
Reese
El Dorado County
Let me try to help.... 150.805 was going to be a CMD 15 but never got the funds to build it out. 155.13 was to be the input to CMD 14. Again no funds to build out. Only Channel fully built out and licensed are Fire Disp, CMD 11, CMD 12 and CMD 13.
Hope this is clear as mud. all info in RR is correct.
kmh603
Santa Clara County agencies are planning to move to 700 MHz trunk system on November 1, 2019!
Eng74
Kern County, CA
When you had 700 System I had to think for a minute then looked it up. Is San Jose moving over or is everyone? I am in the area a lot.
kmh603
Santa Clara City and Sunnyvale have already moved. Santa Clara County and San Jose City will move on Nov. 1st. The other agencies in the County are also working to to move over as they are smaller in size making it relatively easier to transition to 700 MHz and some have already moved.
zerg901
yup
Reese can I ask a couple of follow up questions?
1. Is it true that 155.025R & 155.925R & 153.98R & 154.115R have 5 synchronized simulcast repeaters each?
2. Any idea how many remote receiver sites exist for each of those channels?
3. Is it true that Tac 31 is operationally paired with 155.925R; Tac 32 is paired with 153.98R; and Tac 33 is paired with 154.115R?
4. Does Tac 32 154.31 BM really have a base station?
5. 154.43 is licensed for 3 bases and 400 mobiles - is that accurate?
6. 150.775, 155.13, and 150.805 are used as spare TAC channels - right?
7. 151.04 seems to be unlicensed per the FCC ULS - but there does not seem to be any nearby users - maybe there is an expired license on 151.04?
8. The Radio Reference Database jumps from F1 to F11 - ????
9. Do San Jose field units have the ability to operate in simplex mode on the repeater output channels? ('direct' or 'talkaround' or whatever you wish to call it) - can the dispatchers hear any of that traffic?
10. What happens when someone hits an emergency button? Does the radio remain on its current channel?
11. On 6/22/2019 around 912PM there was a building fire call / microwave plus stove fire ("not getting bigger" per caller) and radio channel "Command 13" was assigned. Engine 35 was sent via radio from another call, and then popped up on Command 13. Engine 35 arrived and gave a report on Command 13 I think. I suspect when the Chief arrived, Eng 35 went to the Tac channel and the Chief monitored both Command 13 and the Tac channel. No tac channel as mentioned. The scanner feed was picking up everyone on Command 13 so that sure sounded like a repeater. (I guess we can call that a confirmation). I did not hear any paging tones for the incident.
Based on all of this - my guess on the channel lineup is -
F1 - 155.025 R - channel name is "San Jose Fire" - this is the home channel for all units
F11 - 155.925 R - "Command 11" - spare command channel
F12 - 153.98 R - "Command 12" - north command channel
F13 - 154.115 R - "Command 13" - south command channel
Command channels are only assigned for structure fire calls, major brush fires, major crashes, major hazmats, etc
Boston has a population of 700,000 and seems to manage fine with 4 repeater channels. San Jose has a population of 1 million. Maybe they are (have been) short 1 repeater channel. But San Jose has Tac channels that Boston doesnt have (do have - dont use).
And that is the end of that. Thanks for being willing to share info. Peter sz
Reese
El Dorado County
Actually more and less. 155.025 ( all dispatching is done on this channel) was built out with a boat load of transmitter to cover the city and remember we had to cover underground in several building and the airport. CMD 11 has the best foot print, because there is a high level repeater in the Santa Cruz mountains, but it's mostly used as a secondary channel to CMD 12 and CMD 13.
Aboat load... as I can remember, most had 10 to 16 receivers.
CMD 11 uses TAC 31 as it's simplex fire ground channel.. CMD12/TAC 32, CMD13/TAC33
NO
You would need to look at the FCC data base. SJ uses an outside agency to do all FCC work.
YES
See answer # 5.
Don't know why..
NO. Too many problems with training the FF to use the Direct Mode. Long history of issues when they had the option. They may have it now.. there was some discussion of adding it back when it retired.
It reverts to the main fire channel. 155.025
Was that a question?
zerg901
yup
Reese thanks a bunch for answering all of my questions. Very informative. Peter Sz
