Sandia Kirtland AFB new trunk help?
n7jei
New Mexico, USA
Hi all....
Got a pro-2096 and programmed it up with ScanCat lite plus to trunk the new Sandia system according to the data here....... no go....
I can hear traffic, even digital on the channels, just won't trunk. Any ideas?
Anyone actually trunking this system? Maybe a different base and offset?
Please help!
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
Did you set the Table?
PGM>TRUNK>FUNC + 3 then navigate /\ to Table on line 4 then press ENTER then SCAN.
Edit: BTW, I can't find 3600 CC or 9600 CC setting options anywhere in the ScanCat Lite Plus program.
I used the Web Import feature in Win96 and the complete program from RRDatabase for Kirtland new with all settings is ready to load to scanner in seconds.
n7jei
New Mexico, USA
Got it Fixed!
Thanks for the help.
That was part of the problem. The program left that parameter as default and not "table."
... Still didn't work, so I checked the table and ... left that at default too! Switched to 12.5 and...
Voila.... trunking.
Thanks again and this is a great resource!
David Hall, N7JEI
Los Lunas, NM
