Sandy Frequencies
scannerfreak21
Henrico, Virginia
Wirelessly posted (Mozilla/5.0 (iPhone; CPU iPhone OS 6_0 like Mac OS X) AppleWebKit/536.26 (KHTML, like Gecko) Version/6.0 Mobile/10A403 Safari/8536.25)
Does know of any frequencies that may or will be active during the storm?
I live in Prince George County if that helps looking for FEMA or other federal stuff as well various STARS Talkgroups.
Troy
scannerfreak21
Henrico, Virginia
Or Anything at all
tglendye
Blue Ridge Mountains, Shenandoah River- VA
During the storm the local PG frequencies and STARS would be what to listen to.
scannerfreak21
Henrico, Virginia
Richmond, VA
Also sky warn is interesting. Even if you don't use a HAM like myself, you can still program a nearby repeater into your scanner and listen in.
Sent from my cm_tenderloin using Xparent Cyan Tapatalk 2
KG4INW
Midlothian, VA
Active ham freqs in the area include the Williamsburg machine at 146.760 (primary Tidewater back to state EOC), the 146.880 in Richmond for Skywarn (direct to Wakefield) and the 145.430 machine in Richmond for the local ARES resource net.
If you can pick up HF, distant stations will try to contact the state EOC on 3947 kHz, LSB.
scannerfreak21
Henrico, Virginia
Thank you so much!
Troy
freqhopping
I've heard some radio checks on PMARS and DC Interop 1 tonight.
WA3CSX
Brentwood,Md PG
also listen to 146.610 Bladensburg repeater,shared with PG ARES/RACES,also 146.955,and if you can 147.300 and 147.105.
scannerfreak21
Henrico, Virginia
Thank You all very much ill use those for sure!
PMARS?
scannerfreak21
Henrico, Virginia
I'm in Prince George County Virgina I should have added that before.
