Saratoga County TRS Official Thread
Warthog1
Silent Key
Northville, NY
Thanks Dave. I have noticed that the primary users were investigators. I have also heard TG 1411 referred to as Sargeant's channel, and I have heard both clear and encrypted traffic there. Any luck on identifying the users of encrypted TG 120 ??
D
DaveNF2G
Guest
I haven't seen anyone use 120. Another original mystery TGID is 101, which also has been unused for quite some time.
I wonder if some of these were test groups that are not part of the regular lineup.
[EDIT] Did you mean 1411 or 1511? I haven't seen 1411 yet.
philb623
Clifton Park, MY
78 79 units
I have been logging UID's for quite a while, and I will throw this one out there for ya.
We know the 71xxxx & 72xxxx units are Sheriff, 73xxxx & 74xxxx are EMS, 75xxxx & 76xxxx are fire, 77xxxx is highway. Now the question, I have logged several 78xxxx & 79xxxx units. Who are 78 & 79 assigned to ?
78xxxx are assigned to New York State Police portable radios.
79xxxx are assigned to all others assigned to the system, radio repair, unassigned portables and the like
philb623
Clifton Park, MY
TAC ID Assignments
Hopefully the following talkgroup assignments will help clear up some of the questions that have come up:
Radio M - 010
Fire 1 - 111
Fire 2 - 112
Tac 3 - 113
Tac 4 - 114
Tac 5 - 115
Tac 6 - 116
Tac 7 - 117
Tac 8 - 118
Tac 9 - 119
Tac 10 - 120 -
Tac 11 - 211 - Fire Investigators (Cause & Origin)
Tac 12 - 212 - Haz Mat Team
Tac 13 - 213 - Fire Coordinators
Page - 511
911 - 1111
Sher 1 - 1112
Sher 2 - 1113
Tac 14 - 1134
Tac 15 - 1135
Tac 16 - 1136
Tac 17 - 1137
Sher Inv- 1319
Admin - 1320
Sgt - 1411
Secure - 1511
Ems 1 - 2111
Ems 2 - 2112
Cap 800 -2211
Dpw 1 - 3111
Dpw 2 - 3112
Tac 21 -3211
Tac 22 -3212
Tac 23 -3213
Tac 24 -3214 - County Wide Emergency
CTAC -4111 - Communications Center
ATAC -4112 - Administation Tac
Lost -5111
Tac 39 -6039 - Mechanicville FD, EMS
Tac 56 -6056 - Saratoaga Springs
Tac 64 -6064 - Waterford FD
NYSP 1 -8110
NYSP 2 -8211
GTR8000
NY/NJ Database Guy
BEE00
Submission? Otherwise without objection, I'm going to update the DB based on that list. I'd like to see you get proper credit for it, though.
philb623
Clifton Park, MY
DB Update
Please do update the data base, but do not worry about giving me credit for it. Through my positions within the county I have access to a great deal of information that others on this forum may not be able to obtain. I am submitting this information for the benefit of everyone who enjoys their scanner.
D
DaveNF2G
Guest
Radio M - 010
Is it possible that 010 is 101? Several of us detected that TGID early on.
philb623
Clifton Park, MY
What is "Lost"?
[EDIT] Thank you for the listing!
If a radio is lost or stolen, the radio can be directed to this Tac instead of bricking the radio. Lost is the only frequency the radio can operate on and is only capible of transmitting to the communications center. It is a way to try to track the radio and to have the person return it to the proper agency
KD2DXF
Nobody
Anytown, USA
Thats actually a really good idea, is there a way to gps the units?
Warthog1
Silent Key
Northville, NY
Still trying to figure out the primary use for encrypted TG 120. This afternoon there was an encrypted conversation between units on TG 120. Some wouldn't show a UID #, but the two that did ID were 721900 & 721911. I know these are Sheriff Portable ID's, but these are mainly the only UID's that I have confirmed on 120, and I'm leaning toward radio repair.
JBAlbany
Pro-197 Reception Problems
Hello,
I am having problems receiving SCTRS. I have tested the scanner on two other P25 systems, and the scanner works great. I can see the "SOLARTOWN INDUSTRIAL PARK" tower in Halfmoon from my house.
Could my receiver be overloaded? Could it be simulcast distortion? I do get some percent of signal, but it is all over the place (30%-90%, no consistency) depending on where I have the scanner and what antenna I use (I have a D3000N Discone). I have tried with and with Attn on.
Any suggestions?
Thanks.
JB
KB2RSK
Fort Plain New York 13339
Montgomery Co NY
I have the Pro 106 and was wondering if there is a close by digital Trunk System other than the NIMO Utility that is listed on the RR Files, that will be or is working that I should be able to receive in Montgomery County NY
Thank You
Also anyone wishing to QSO me on HF I can work any mode
73's From KB2RSK
My grid Square is FN22 for my location
snorkle
GLOVERSVILLE N.Y.
saratoga co radio
You should be able to receive saratoga co trunk system. I have a pro-106 and can get it all the way to esperence.
wb2gye
D
DaveNF2G
Guest
Thank You
73's From KB2RSK
NiMo (National Grid) is not trunked. Some of their repeaters are digital.
NYSEG is P25 trunked on VHF high band.
oem316
Schenectady
SCTRS on BCD996XT. In colonie
I have loaded the new system from RR and get nothing to no avail. I have even made sure the the north and south systems have the correct channels listed and that i have every CC right, but i still get no signal of findingCtlChanl on my scanner. Have tried it both base and mobile side same thing you cant any help appreciated
snorkle
GLOVERSVILLE N.Y.
p25 saratoga county
go to marksscanners.com. you must reband your radio and enter p25. Just put in the 4 control channels. chose 1 site , either the north or the south. you should first scan between 851- 855 mhz , to see if your radio locks on the control channel. they are using cc#3. good luck
wb2gye
