sarpy county
youcandoit
Cornhusker state
can some one tell me if the freqencies i listed below
are unencrypted or encrypted
866.0125 156.7 pl co8
866.5125 156.7 pl co9
867.0125 156.7 pl co10
It'd be more helpful if you tell us what agency you are trying to scan. I took a quick look in the database and didn't even see those frequencies listed. Where did you get them? What agency?
JoeyC
Senior Member
San Diego, CA
Those look like 800mhz ITAC freqs. and NO they are not going to be encrypted.
youcandoit
Cornhusker state
i found them in the rr database
look under
rr mobile/rr database/united states/nebraska/common shared/
nebraska 800 mhz mutual aid
and thank you for your help.
mikeoz
Nebraska
Sarpy County
The 860 frequencies are rebanded
Check your PM and email back if questions
Ok, now I know what you are talking about. There are two tables there for NE Mutual Aid. The top is the old frequencies used before rebanding. The other table lists the rebanded frequencies and I have picked up traffic in the form of CW ID on 851.30000
Now whether someone else is using the old frequencies I have no idea.
As for your original question, as far as I can tell, the broadcast is in the clear with no encryption. I say this, because as I indicated above, I have picked up CW ID.
Hope this helps answer your question.
Douglas County is using both sets of frequencies, Icalls and Itacs. They have set up temporary repeaters for the non rebanded frequencies. They will remove them once the rebanding process is completed.
