RBerezowski said:Yes, it is APCO P25 digital compliant. The network is an EDACS P25 VHF trunked network.
boomboy64 said:Having talked to a few people, I was under the impression that it was a "True P25" system, using P25 Trunking, not EDACS. Yes, the equipment is from MA/COM, but not EDACS.
Comments?
Boomboy
Hi you can use any P-25 capable scanner : Radio Shack PRO-96 /Bearcat BCD396T/GRE PSR-500 and others out there to listen to the new system. These digital scanners are legal in Canada and I hope you buy one and we welcome you to join in with this forum for any help you may want with programing your new toy!TrunkLid said:So what kind of scanner will I guy need for this new digital signal?
Are those digital scanners legal?
just got a pro 96 but am totally lost on how to make it work in southwest sask. any help would be appreciatedmobile1 said:Hi you can use any P-25 capable scanner : Radio Shack PRO-96 /Bearcat BCD396T/GRE PSR-500 and others out there to listen to the new system. These digital scanners are legal in Canada and I hope you buy one and we welcome you to join in with this forum for any help you may want with programing your new toy!
Hi to diamondc in S.W. Sask ! First things first we must find the frequencys in your location. Go to page #53 of your user manual , turn on the radio , it must be 10 feet or more from your P.C. to work properly! press SRCH until SR6 is in the top left of the display.Now go to page #58 1-2 and page #59 3-6 and enter 138.0000 for your lower limit and 144.0000 for you upper limit ! The control channel will be on all the time, push the arrow key each time it locks up on this channel . Use the pause key to hold when it stops on a voice channel , push pause again to continue your search until you get all the channels for you area. There may be only 2 or as many as 16 or more just make a note of each so you can enter them later. You must read the manual , take your time , understand how to use your new scanner .Do not get in a rush the learning curve is steep and many users become frustrated but it is time well spent. Good luck and thanks for joining in with this forum!diamondc said:just got a pro 96,brand new to scanning & am totally lost on how to set up for scanning rcmp in sw sask. any help will be appreciated
what does it mean when it say's all channels are locked? thanks for the helpmobile1 said:Hi to diamondc in S.W. Sask ! First things first we must find the frequencys in your location. Go to page #53 of your user manual , turn on the radio , it must be 10 feet or more from your P.C. to work properly! press SRCH until SR6 is in the top left of the display.Now go to page #58 1-2 and page #59 3-6 and enter 138.0000 for your lower limit and 144.0000 for you upper limit ! The control channel will be on all the time, push the arrow key each time it locks up on this channel . Use the pause key to hold when it stops on a voice channel , push pause again to continue your search until you get all the channels for you area. There may be only 2 or as many as 16 or more just make a note of each so you can enter them later. You must read the manual , take your time , understand how to use your new scanner .Do not get in a rush the learning curve is steep and many users become frustrated but it is time well spent. Good luck and thanks for joining in with this forum!
