Sat on my radio and broke the antenna
Bal222
Radioshack Pro-96. Looking for replacement. There's a gazillion antenna's out there. Different types, different frequencies, etc.
Not sure what to get exactly. Just looking for a "standard" replacement but would go for an upgrade if something is available.
Any suggestions?
Whiskey3JMC
_/|\_Surf's up, Happy DX!
Simulcastylvania, TE
What is (are) your primary band(s) of listening interest? How much are you looking to spend? Pretty much any antenna upgrade will be a significant improvement over the stock antenna that came with the scanner. If you're looking for a telescopic I recommend the Comet BNC-W100RX. Fully adjustable per band and collapsible for storage without having to remove it from the scanner. If you listen to 700/800mhz and not much else, consider the Remtronix
Bal222
The Comet covers the range of the radio so that should work. Does it work OK collapsed or does it need to be extended and adjusted to use for different frequency ranges?
Really don't want to have to do that. If it works OK when collapsed and you can extend it for extra range or clearer signal that would work.
iMONITOR
Silent Key
S.E. Michigan
Any suggestions?
REM 800B
bb911
SoCal
I have an OEM antenna for my Pro-97 which may be the same antenna that you broke. You can have mine for free + cost of postage, even if you purchase a new one. I guess that indicates what I think of the stock antenna. It may take a while for me to find it though. Having said that, the best handheld scanner antenna that I've ever owned is the Laird/Larsen 2m/440 ham radio antenna. ("green tip"). Yet having just checked out the antenna mentioned by vagrant (immediately above), it seems likely that it is superior to the one I just mentioned. It is very pricey though.
Bal222
Just ordered the Comet listed above. Probably over thinking this.
Worst case I get some experience with a collapsible antenna.
Whiskey3JMC
It should be extended for optimal reception, there's a guide on the side of it telling you which lengths to extend for which band. Generally the lower the band the more lengths you extend. In addition to the telescopic lengths it also has an elbow joint so you can collapse the antenna to fold along the side of the radio for storage. Pictured are the BNC version on my AOR AR-DV10 & the SMA version on my Uniden SDS100
vagrant
ker-muhj-uhn
California
I do not use a telescoping antenna with a scanner as I am not in the mood to rapidly extend/collapse the antenna as the frequencies are swept. Of course strong signals should get through when in a fixed position, even if the antenna is not tuned for it (too long to too short). I hope it works out for you.
iMONITOR
Silent Key
S.E. Michigan
You have to be careful when the telescoping antenna is extended not to put too much stress on the BNC connector on the scanner.
n5ims
Remember that an antenna is pretty much all about frequency. Mode doesn't matter, analog, digital, whatever if the frequency is right the antenna will work just fine. Polarity is important on all frequencies. For nearly all scanner activity, you'll want a vertically polarized antenna. On a hand-held, that indicates that you'll want the antenna pointing straight up and down for best reception. Be aware, however, that in some circumstances, you may find that pointing the antenna in other directions may give you better reception due to the signal being bounced around on buildings or other objects. For transmitting, keep the antenna pointed up and down though.
There are some great 800 MHz antennas on the market so if you only listen to the many trunking (or standard) systems that transmit on 700, 800, or 900 MHz bands (often called the 800 MHz band), they will do you well. What they won't do well on is the VHF-Hi (120 - 170 MHz) or UHF (420 - 480 MHz) bands. Similarly, there are good antennas for VHF-Hi band that won't work well on the 800MHz band. Some may work well on the UHF band, some won't. There are also dual-band VHF-Hi/UHF antennas that work well on both bands but still not so well on 800 MHz. If you listen to the VHF-Low band (30 - 50 MHz) there are a few that will work well on that band but they'll be quite long and not work as well on the other bands.
Be aware that many sellers will have an antenna that is designed for one thing but they'll say it will work on everything on the planet (and some from outer space!). If they list where the antenna will transmit then remember that that's where it will receive properly as well and ignore the rest of the hype. If they say that their antenna will work from 30 MHz through 1.5 GHz just know that they're lying and move on. You don't want to be stuck with a bad antenna just because they lied about the specs.
