You could spend a few hundred, or thousands to do this.
Less: Handheld dual band radio like Kenwood D72 for FM only birds with an Elk Log periodic or Arrow antenna. Walk outside and aim the antenna along the bird path.
More: Icom 9700 for FM/SSB birds with an azimuth and elevation rotor along with either two single band Yagi antennas, or an array of several antennas. The rotor will need a controller and you will use a computer and software to download the Kepler data and have it auto track the birds when they come by. ( The software on your computer would need to link to the controller and steer it )
There is some room between, but you need to consider how, when and where you will operate. I don't work the amateur satellites that much, so others may have improved information.
