scannerface27
Ok, so I run the feed for san bernardino system 1. Last night I turn on my 396xt and no traffic, check everything no probs. Go to a channel for apple valley, and it is trying to find control channel.. really weird there are only four cc for this system all are put in, keep in mind a splinter system. So I check my three other scanners same issue no control channel, but if you step through thr frequencies manually you can here little hissing not chop, but that is normal, then i stopped one one of the four rotating cc's and got a beep. So going through the channels again, manually I here traffic.. what the is going on... Does anybody know if they are testing or added another cc, that is not listed.. this has never happened before with this system... The other systems within the county are working fine... pleas e help
