All you will need is a pc to download the oddcast software on and let it run 24x7. Then Other than that all you will need is a single cable that will plug into both your computer headphone jack or mic/line input jack and the other end into your headphone jack on your scanner, Then tell Gordon what areas you will be broadcasting for.. Send him and email at
gordon@scanamerica.us for more info. He can set your feed up and let you know what all you will need, however I think I have listed it all, When all said and done and broadcasting online be sure and post here so we can all have a listen in once in awhile, Hope this helps.
