- Joined
- Oct 27, 2002
- Messages
- 2,353
- Reaction score
- 1,342
I have made a configuration change to my live scanner feed. This has resulted in improved performance of the alpha tagging portion of the scanner feed. The only software that will display the alpha tags is Winamp. It can be downloaded from http://www.winamp.com . The link to the Winamp feed is:
http://www.scancapecod.net/livescan/feed.m3u
The audio only feed is still available as well, but I would strongly recommend using Winamp for the best results and the alpha tagging. If you are resigned to audio only, use the following link:
http://www.scancapecod.net/livescan/capecod.m3u
If you are interested in setting up this type of feed, I have written a 20 page tutorial outlining its setup, which is available at:
http://www.scancapecod.net/livescan/feed_tutorial.pdf (Adobe Acrobat)
http://www.scancapecod.net/livescan/feed_tutorial.doc (Word)
Enjoy the feed, and Happy Holidays to all.
