Scan List Program ABC Switch XTS 2500
idle00955
Manch NH
For some reason I cant edit the scan list. I have the abc switch set to scan, blank, scan list prog. When I goto scan list prog it shows me what is in the scan list and says sel-del-rcl but if I press a button nothing happens. Did I miss something in the CPS?
bezking
On the Road
Go into the scan list in CPS and under the General tab, make sure "Non-Priority Members," "Priority 1," and "Priority 2" are set to "Operator Select."
Edit: actually, if you aren't using priority scan, you just need to change "Non-Priority Members."
RKG
Boston, MA
I strongly urge customers NOT to use a switch for entry into scan programming mode. The reason is that if you inadvertently enter scan program mode via a switch, the radio will stay there forever and while in that mode it won't work. You'll end up calling me to "fix" the radio.
Scan programming mode entered either via a menu or a long press of a sidebutton will time itself out to regular operation if no entries are made.
Note that you don't need a scan program mode menu item if you've programmed a side button for "scan," as a long press of the same button will enter scan programming mode.
FFPM571
Nashvillle
I use the ABC for scan on and scan off A scan on, B scan off C PL defeat. Im the only one who uses it so I am familiar with it .Its the same on all my XTS's
RodStrong
West
If you have scan prog via the concentric switch, the radio will sound a solid tone if you fail to do something while in it or fail to get out of it, therefore reminding/warning you to get out.
RKG
Boston, MA
So I'll get a call asking "Why is my radio beeping?" Usually well after dinner.
RodStrong
West
Perhaps, but of the hundreds of radios under my care that are programmed this way, and amongst the hundreds of users that I have trained, this has never once been an issue. The radio doesn't beep by the way. It's a steady tone that is quite the attention getter.
