Scan Lists Changing between
Ryanmackphoto
I’m sure this will be answered quickly but I can’t seem to figure out how to change In-between my different scan lists. Currently have 3 set up. Running a xts-5000 with no FPP.
thanks!
K2NEC
You change the scan list in the software. 1 Personality has 1 assigned scan list. You can't have more than 1 scan list per personality
Conventional>Conventional Personality>Personality>Scan>Scan list selection
chrismol1
P25 TruCking!
Either setup channel 1,2,3 with scan list 1,2,3 and turn the knob per scan list and/or setup a menu item PROG and edit the scan list for the channel your on
Ryanmackphoto
Here’s my updated question
K2NEC
Updated answer:
You can have as many scan lists as you want. You can't toggle the scan lists from the front of the radio. You assign a personality to a scan list and then you assign the channel in the scan list. Once it's been programmed you can't change a channel from scan list 1 to scan list 2. It must be done in the software.
"How do I toggle between scan lists in my radio"
Simple answer. You can't.
Ryanmackphoto
So in other words I can Only run one scan list at a time on my radio. Thanks for the help!
Ryanmackphoto
Dang! Would be useful to be able to run different scan lists when I’m in different areas but thanks!
K2NEC
It would but you have to remember, a radio isn't meant to do extensive scanning. Or be very good at scanning. That's what a scanner is for.
marcotor
I ♥ÆS Ø
Sunny SoCal
Thats what Zones are for. Program individual Zones to match the area frequencies you want to monitor. Assign scan list. Profit.
nhfdcadet
New Hartford, Ct
you assign the scan list to the personality. When you put your channel into a zone you assign it to a personality, that personality has a scan list assigned to it. you can't just tune to a channel and pick what scan list you want to listen to. What you can do is make your scan list editable so that you can add different channels to it if you need to.
or you just build your different lists you want for different areas, and assign them to different personalities which you assign to different channels in the radio, so when you are on that channel it scans the assigned list.
