Scan on an XM-100F
N1GTL
CT
I am trying to program my first Harris radio and I cannot figure out how to scan 3 channels. All channels are analog and all conventional systems, no trunking or talk groups. I am using RPM. I have all the channels assigned to their respective zones.
Can someone point me in the right direction?
emtLarmy15
Pocomoke City, MD
I can't speak for the xm100 but most other Harris radios (as long as programmed right) the scan list is modified in the radio after programming
N1GTL
CT
I do have instructions on how to add things to the scan list from the control head. But, from the help file in the software:
If this control is set to "Fixed", the radio user cannot modify the default scan list from the radio keypad. Changes to the default scan list must be made by the PC Programmer.
I want to put three channels in the list and do not want the end user to be able to edit the list. Based on the above, somewhere in the program is a way to create a list....I just can't seem to find where.
N1GTL
CT
I had to go through three different screens but finally got it working. Yes, the check box under the "conventional frequency set" was checked. There were a few other menus that required simple settings.
Thanks for the help.
