Scan Set selection
rayvelcoro
I decided to try out the selectable scan set feature of the TRX-1. I set up scan lists for scan set 2, de-selected scan set 1 and everything worked well scanning that alternate scan set. Later in the day, I went back to selecting scanlists for scan set 2 and realized that the radio would only allow me to scan the usual scan set 1 without the notification: "Nothing to Scan!" I've read the instructions and tried everything but I can't get it to work like it did the first time, allowing me to scan scan set 2 instead of scan set 1.
What am I missing?
JD21960
ILL-annoyed
Sounds like you left one of them unchecked and tried to scan it. You can only have one Scan-SET selected at a time while the other is unchecked. Changing back maybe you thought you "saved" it by pushing the "save" but it really unchecked the box? here's what my Scan-SET box in EZScan and scanner looks like. If nothing is selected? that's what the message says. Scan lists need to be enabled in each SET
