Scan
radios4bill
N/E Ohio
Hi Group; I ordered a G5 today and i was told by a friend that you can not scan more the one system in a Zone. On my APX there is Multi Site scan and you can scan more then one site. Can anyone conform or deny this? Thanks, Bill
sefrischling
New London, CT
I was just informed the G5 cannot scan even trunked and conventional simultaneously. I know it cannot scan two systems at once. I was looking to scan a single 800 P25 TG and a VHF conventional frequency , but that's a no-go.
APX8000
Sarcastic Member
AES-256 secured
You are both correct. You can only scan one system at a time and a max of 64 talk groups on that system per knob position. You cannot scan conventional and trunked at the same time. You have to remember that the G5 was meant to be used as a pager where you monitor let's say a VHF or UHF analog conventional dispatch channel. Once alerted to a call, you can then change the knob position to monitor let's say the response and operations talk groups on a P25 trunked system. Scanner hobbyists have found that this little thing has a really great receiver and handles LSM Simulcast distortion better than any Whistler or Uniden scanner. So it's not really built for multi-system scanning or conventional and trunked scanning together like a traditional scanner or APX radio.
radios4bill
N/E Ohio
Thanks for the info. You can put and monitor multi system correct? It will only monitor one system at a time, correct!
APX8000
Sarcastic Member
AES-256 secured
I have 34 systems in mine some with multiple sites like NC VIPER, Palmetto P25, SEGARRN, etc. So yes.
sefrischling
New London, CT
Personally I want to use it as a public safety pager, so I can use one pager instead of two for monitoring two adjoining towns. One is 800 trunked, the other is VHF. Which is why I was looking into it.
sparklehorse
Portland, Oregon
You can program multiple sites for one system if you want. The G4/G5 will first try one of your programmed sites at random, and if that control channel signal is good it will remain locked on that site unless the signal quality degrades beyond a certain point. If you then move out of range of that site, the radio will attempt to find a different site with a better control channel signal. Works well in my area where we have two different simulcast sites, each covering a different part of the county, but carrying the same talkgroups.
parma,ohio
can anyone send me a code plug for the G5V Pager so i can look at how you did yours i know i have to Import that to the Unication Software.
APX8000
Sarcastic Member
AES-256 secured
I fee like I'm listening to NA on DMR...all these codeplug requests, LOL.
One of the biggest things about this hobby is the learning process. The software is not that difficult to use. In other forums we call this "spoon feeding." If you have questions, please ask. But I feel you have to take the time to play with the software and learn through some trial and error. Don't you all remember when we had to program scanners by hand ? Now you can just download everything. And that is why people don't understand how things operate.
parma,ohio
never mind asking was just making sure i have the P25 Conv channel correct for monitor each one.I'm Building up a code plug so when i get mine all i have to do is program it thanks anyways
radios4bill
N/E Ohio
Dave and I are friends and are in the same area and I just wanted to know how to share mine with him. Thank you for your help.
APX8000
Sarcastic Member
AES-256 secured
Pm me your email and I'll send you mine. I have some conventional in their as well you can see how I have it set up.
APX8000
Sarcastic Member
AES-256 secured
Dave and Bill....just send you a good file to help you out. The conventional stuff is a real pain and I didn't understand it at first. I also don't like how it displays "CSQ" on the screen big when scanning and the actual freq displayed very small. I sent a request to Unication to change this also along with other suggestions.
