Win 97 Queston
thebiker said:
Just got a new pro97.Nice!RS programed the first 2 banks using scancat.
I want to try win97.Question? Do I need to clear(delete)the scanner of what RS
did to use win97.Thanks,Dan
1st ) Make sure you have the correct cable RS#20-289 (serial-pc/if) or the NEW GRE( usb -
pc/if) @ greamerica.com.
2nd) You can dowload & save the RS Scancat program files using WIN 97.
3rd) The 97 also comes pre-program Chan 000 - 154,Turn Off scanner ,then turn On,
When Multi-system Trunking System appears,Press PGM,Press 1(doing this will replace
what's in Chan 000-154.)this is a great set of general radio frequecies.You can also
dowload & save w/win 97.
4th) Remember when you upload will wipe out what ever you have in the scanner.
But between these two files you can pick the frequencies you want and add or remove
from these files.
5th) Remember to have fun and win 97 makes it easy ???
