Hi,
I have a ScanKing Royal Discone 2000 and want to reduce electro inteferrence.
My simple question is; which end would i place Ferrite Core/s ?
1. At the base of the Antenna, where the PL259 Plug is?
2. At the base of the Antenna, and a second at the end of the wire where the reciever is?
3. Just at the end to the receiver?
4. or one just Centre of the cable that runs between the Aerial and Reciever?
Reason i ask this is, i want to cut interference to a minimum, though do not want to lose valuble interference. One such interference i wish to cancel out is Electrical 240/220V.
I also have the use of a Jim M-75 as a pre-amp, so can separate frequency bands - Nice Pre-Amp by the way!
Also one more thing about this Antenna.
If its capable of Transmit and Recieve from 25-2000MHz (2GHz), is there a specific SWR this should be set too, and at what frequency should this be calibrated too, as im not going on my roof ever hour to SWR into the next frequency.
And one last question:
My old Antenna was a Sigma SE-1300, worked great until snapped off my roof.
Though between the Sigma SE-1300 and the ScanKing Royal Discone 2000, is there any performance difference?
The noticeable difference i see is that the SE-1300 uses hollow Ground Planes, and the ScanKing uses Stainless Steel Ground Planes, which im sure improves the life span. There is also a slight difference between how the N-Type Connector links up to the whip with the SE-1300 and a more stronger connection for the plug.
The SE-1300 when snapped off my roof, every ground plane had a lot of corrosion.
Anyway, my initial question is what is most relevant with the Ferrite Core/s.
ScanKing - Make sure this surface is clean as they come with some sort of glue which interfers with connection, i sanded this smooth.
The SE-1300 Ground Plane - Well corroded.
ScanKing Discone 2000 Centre/Hub
The dead Sigma SE-1300 Hub
Dont know where the whip went from the Sigma SE-1300, just went with the wind.
One other thing, with using Ferrite Cores, will this impact SWR for the worse (TX & RX) ? Im guessing it would improve, though calibration of SWR would be more tedious to make precise? As in where to precisely place the Ferrite Cores on the Cable. Like balancing an Alloy Wheel as an analogy.
