scann help
biferi
If I am at a shortwave radio that displays in MHz and it is showing a display of
2.696 MHz
I know this is 2,000,696,000 Hz
But if I go to a shortwave radio that displays in kHz and I want to listen to the same FREQ what do I put in?
kb2vxa
Banned
Point Pleasant Beach, N.J.
The decimal system is the simplest of all, to change units move the decimal point. Everything is times 10 to the left as in the above example or divided by 10 to the right.
biferi
thanks but
Thanks for getting back to me but I think I sould explaine were I get mixed up.
If I am on a radio and it is displaying in MHz and it says 2696 MHz I sould read it as 2 million 6 hundred and 96 thousand Hz
Now if I am on a radio that displays in kHz and it displays 2696 kHz would I read it as 2 million 6 hundred and 96 thousand Hz
kma371
Not sure where your going here...do you still need help or did you figure it out?
2.696MHz = 2696 kHz
stevenlee
help with radio
how do u pick up phone calls on a scaanner either cordless phones or cell phones,,
kma371
Don't thread hijack (aka, Your post has nothing to do with this topic). It's not allowed.
Suggest you start a new thread.
Jim41
2.696 MHz is 2 million 6 hundred and 96 thousand Hz (note the decimal point)
2,696 KHz is 2 million 6 hundred and 96 thousand Hz (note the comma)
2 MHz is 2,000 KHz
Jim41
DickH
I think you are giving everyone a headache.
biferi
thanks but
OK I think I have it.
A radio that displays in MHz will say 2.696MHz and it will put a Decimal Point after the two.
A radio that displays in kHz will say 2,696 kHz but it will put a Comma after the two.
And I know some radios that display in kHz will not show the Comma I get this.
But what I never got is this?
if a radio displays 2.696 MHz and you see it on another readio as 2,696 kHz it is the same FREQ.
Now I know 1 kHz = 1,000 they put the k so they don't have to put all the zeros I get it. So they can display 2,696 kHz and the kHz tells to you to read it out as 2,696,000 Hz.
So if I see a display as 2.696 MHz does this not tell me to read it out as 2,696,000,000 Hz?
Because M means to ad six zeros?
RDGDigital
MD - Eastern Shore
No!() M does not mean to add six zeros, it means to move the decimal 6 places so 2.696 MHz = 2,696,000 Hz. Or in other words...
2.696 MHz = 2,696 KHz (decimal moved three places to the right) = 2,696,000 Hz (decimal moved six places to the right). These would all be the same frequency just using a different notation to identify them.
Rick
biferi
thanks but
This is what I sould have asked?
If I am on a radio that tunes in with kHz and see 2696 kHz I would say
2 million 6 houndred and 96 thousand Hz
But if I am on a radio that tunes in with Mhz and I see 2.696 MHz would still say
2 million 6 houndred 96 thousand Hz?
kma371
You are making this WAY, WAY, more complicated than its needs to be. It's just
2-6-9-6 kHz
2-point-6-9-6 MHz
On phone numbers do you say
925-555-1212
Nine billion, two hundred fifty five million, five hundred fifty one thousand two hundred and twelve?
No. You just read it.
2-6-9-6 kHz
2-point-6-9-6 MHz.
That's it.
biferi
thanks but
OK so if I would still say both FREQ. the same what is the deal with the point in the MHz freq. readout?
k tells us to ad three zeros at the end.
And M tells us to ad six zeros at the end RIGHT?
kc4jgc
Virginia Beach, VA
I'm really wondering why you're so confused. Then I see you original post
2.696 MHz
Actually 2,000,696,000 hz=2.000696 GHz (gigahertz).
Back to your example:
2,696,000 hz can also be expressed as
2,696 khz (decimal moved 3 positions to the left) which can also be expressed as
2.696 Mhz (decimal moved 3 more postions to the left) which can also be expressed as
.002696 GHz (decimal moved 3 more positions to the left) which can also be expressed as
.000002696 THz (Terahertz)(decimal moved 3 more positions to the left) .
As kb2vxa and k9wg said it's that easy. Like any metric measurement, all that's done is moving the decimal 3 positions either way.
Clear now?
