Here is your Cherokee County favorites list. Save the attached zipped file to your computer and extract. Go to the File tab in Sentinel and click on Import from hpe file (Favorites List). Click on New Favorites List and name it
Cherokee Co NC Click on OK. In the Downloads folder, open the extracted file. It will appear as a favorites list in Sentinel. Go to the Edit tab and click on Edit Profile. Click on the Scan Selection tab. Remove the check mark from Monitor Full Database. Turn on Download and Monitor for the new favorites list. Turn off Download and Monitor for any other favorites lists. Close the Profile Editor. Go to the File tab and click on Save. Turn on your scanner. Plug the programming cable into your computer. When you plug the cable into the scanner, you will get a message to press E to enter USB Mass Storage. Press E on the scanner keypad. Go to the Scanner tab in Sentinel and click on Write to Scanner. Check the box to Erase Favorites Lists on Scanner. That will give you a clean start. Click on OK. Once the transfer is completed, eject the scanner and unplug the cable. I will give you instructions a little later about using quick keys. Quick keys as follows:
Cherokee Co NC | | |
SYSTEM QUICK KEY: | | |
*. Cherokee Co Trunk | | |
DEPT/SITE QUICK KEYS: | | |
0. Statewide Events | | |
1. Statewide Interop | | |
2. NC Emergency Management | | |
3. NC Dept Prep & Readiness | | |
4. NC National Guard | | |
5. NC Helo & Aqua Rescue | | |
6. NC Civil Air Patrol | | |
7. NC Forest Service | | |
8. NC State Highway Patrol | | |
9. Cherokee County | | |
*. Cherokee Co Blank | | |
*. VIPER Murphy (Site) | | |
10. VIPER Hot House (Site) | | |
11. VIPER JoannaBald (Site) | | |
0. Cherokee Co Conv | | |
DEPT QUICK KEYS: | | |
0. Cherokee Co Services | | |
1. Cherokee Co Fire/EMS | | |
2. Cherokee Co Local Fire | | |
3. Cherokee Co EMS/Hosp | | |
4. Cherokee Co Sheriff | | |
5. Cherokee Co Local PD | | |
SYSTEM QUICK KEYS: | | |
1. Cherokee Co Sheriff DMR | | |
2. Valleytown Fire DMR | | |
Note: (* = None) | | |
