Scanner and CB Radio
cvwinters
Corvallis Oregon
I am a recently retired from accounting and just getting into using a scanner. I purchased a Whistler digital scanner (BNC Connector) and just ordered a Tram 1411 base antenna. Here is the issue. I have an old 23 channel Cobra CB base station and I want to use the same antenna to operate both. Is this possible? Also, what cable would be best -- RG6 or RG58. I assume I can use a splitter inside the home to switch back and forth between the two radios? Sorry for probably asking dumb questions. Am researching as fast as possible. Thanks for any advice.
buddrousa
The CB antenna will give you some reception but it is for 27 meg your scanner is going to want to see 150 meg 460 meg 700 meg and 800 meg depending on where you are and what your local agencies use.
Using a splitter is a bad idea your CB will send transmitted power into the scanner and that will kill the scanner. What are you wanting to listen to the most on your scanner?
cvwinters
Corvallis Oregon
Scanner and CB
Sounds like a splitter connected to both units is a bad idea. How about if I split the cable, but only have one plugged in at a time. For the scanner, I am interested mainly in police/fire/emergency type transmissions. From what I have read, an RG58 cable would work for both. What do you think?
cmdrwill
So Cali
What you would need is a coaxial switch. That will allow ONE radio/scanner at a time.
Go with at least RG8 coaxial cable.
buddrousa
It all goes back to what you want to hear. I know people that have bought LMR400 $1 to $2 per foot because it is less loss. But as some have learned with some systems more signal is not a good thing.
Again I ask what is it that you are wanting to monitor with your scanner. We can offer more advice the more we know.
The Tram 1411 is a discone and it's advertised as being useable for transmitting from 26MHz to over 1200MHz.
It'll work as a CB antenna, but probably not a really good one. You'd get better performance from a dedicated CB antenna.
You cannot hook the two radios to the same antenna at the same time. As was stated above, the 4 watts RF from the CB won't play nice with the soft mushy bits inside your scanner. Likely it'll result with a damaged scanner.
You need to do one of two things:
Separate CB and Scanner antennas.
or.
As stated above, a switch that would let you select between the two radios and the one antenna.
As for the Coaxial cable, of the two the RG-58 is going to provide the best impedance match for the CB, but the RG-6 would probably work with slightly higher SWR. The RG-6 will probably get more signal to/from your antenna (which is what you want).
Unlike popular misconceptions, your CB will not instantaneously blow up if you use the 75 ohm rated RG6 cable. There will be a slight mismatch, but probably not enough to be an issue. The slight impedance mismatch will create slightly higher SWR and will lose some of your signal as power reflected back to the radio and be dissipated as heat in the final RF transistor. Over time this can do damage.
Depending on the distance from your radios to your antenna, you will probably do better with a higher grade coaxial cable. The longer the cable is, the more signal you will lose. If you use a low end cable, you can have enough lose in the cable to lose signal. Lose enough of the signal and you won't hear what you want to.
Ideally you really want the antenna as high up as you can get it. The higher it is, the farther away the "RF Horizon" is. Since many UHF/VHF frequencies work more by line of site, the more your antenna can see, the more you'll hear.
If you use cheap/low grade coax, you'll lose a lot of the gains from the higher antenna.
What really matters is how long your cable run will be.
I won't recommend a cable without knowing how long the run is and what you budget and expectations are. Share some more info and we'd be able to offer some additional help.
