BITT211
Which is stronger reception scanner antenna ,
tram uhf 406-512 mhz [6.5 gain] omnidirectional type
or
yagi uhf 450-470 mhz [7.1 gain] 3 elements
have the tram mounted on 50' tower , my location is higher elevation
tram is working fine , hooked into a striedsburg powered coupler , heliax coax- 7/8"
looking for a little more distance , i am located on the rear part of my county so very little reception would be coming from rear of yagi . The yagi cover pattern would be fine for my coverage i need.
Would it be worth while in replacing tram with yagi ? Tower has tilt base , no problem there..
Thanks for any input
or
