Scanner Antenna
BlueDevil
WA
Are you looking for a replacement for the stock telescoping antenna or and upgrade?
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
This question is in the wrong forum - I'll ask to have it moved here...
Scanner / Receiver Antennas - The RadioReference.com Forums
Once that scanner has a proper antenna jack, there are a couple of possibilities here. A good mag mount with a Larsen antenna (link below) would do the job, or just throw together a wire version of the Off center fed dipole, link also below..
PulseLarsen NMO-150/450/800 Antenna Mobile Tri-Band Other, NMO150/450/800
Homebrewed Off-Center Fed Dipole - The RadioReference Wiki
Mike
LATA 722
I agree. The thread in telescopic antenna will limit performance choices. Adding an external antenna jack will open up the possibilities. Moving an external antenna, preferably one designed for the frequencies you want to listen to, closer to a window will help a bunch.
If you are not comfortable doing that modification, then find a replacement. I don't know what the thread is like on the stock antenna, so you might be better off calling Radio Shack/Whistler directly and asking them for a replacement.
riccom
Upstate S.C.
Spartanburg, South Carolina
here is the back of the unit
trp2525
There ya' go then.
This magnetic mount: http://www.theantennafarm.com/catalog/larsen-nmommrbnc-4522.html
This antenna: http://www.theantennafarm.com/catalog/larsen-nmo150-450-800-1050.html
Stick it on a file cabinet, metal shelf, cookie sheet, something to provide a ground plane under the base and plug it into your scanner.
That's work much better than the telescopic antenna.
Another option to try (if you have a window air conditioner with a metal cabinet) would be to put the magnetic antenna mount outside your window in the center of the metal cabinet of your window air conditioner.
