Scanner Birdies
jonwienke
More Info Coming Soon!
VA
Look up IFX (intermediate frequency exchange) in the scanner manual. If that doesn't make the signal go away, it's not a birdie, but an actual signal.
Ubbe
Stockholm, Sweden
Func+7 is IF exchange and will switch one of the oscillators to another frequency.
Birdie is an interference from the oscillilators in the scanner, could also be from a switching power device for the display or something similar. If it affects your scanning and IFX doesn't help you just give that frequency a permanent lockout when you encounter it.
/Ubbe
popnokick
Northeast PA
Birdies will be present at the same signal strength when you disconnect the antenna, which is another way to determine if it's actually a birdie or an external signal.
