FEDERAL EMERGENCY MANAGEMENT AGENCY:
FEMA VHF & UHF FREQUENCIES:
138.100
138.225 ** NATIONWIDE Primary Repeater; (Repeats. 141.875)
138.575
139.100
139.225
139.450
139.825
139.925
139.950
140.025
140.900
140.925
141.725 ** NATIONWIDE Primary Simplex
141.875 Repeater Input to 138.225
141.950
142.025
142.200
142.230 Repeater Input 142.975
142.300
142.350 Simplex; Repeater Input to 143.000
142.375 Simplex; Reg. 09, 10, Repeater Input to 143.000
142.400 Simplex; Reg. 04
142.425 Simplex; Repeater Input to 143.000
142.925 Simplex; Reg. 02, 03, 05
142.935
142.950
142.975 Simplex; Repeats 142.230; Repeater Input to 143.000
143.000 Simplex; Repeats 142.350
Repeats 142.375
Repeats 142.425
Repeats 142.975
143.050
143.225 Mobiles
143.250 Repeater Input to 139.250
143.600
143.625 Simplex; Reg. VI
152.425
153.225 Repeats 158.130
158.130 Repeater Input to 153.225
163.100 DOE Common, National Emergency Training Center
163.225
164.8625 Ch. 2, Simplex; National Radio System
Ch. 1, Repeats 165.6625; National Radio System
165.6625 Repeater Input to 164.8625,
Simplex; National Radio System, Emergency Training
166.225 National Emergency Training Center
166.6125 Repeater Input to 168.400
167.925 Simplex; Regional EOC Net 4
167.975 Simplex; Regional EOC Net 2,
Some DoD, DoE, NASA, NOAA, NRC Facilities;
Repeats 173.1875; Regional EOC Net 1
168.075 Repeats 170.425
168.100 Repeats 170.450
168.350 National Emergency Training Center
168.400 Repeats 166.6125
168.700 Repeats 170.975
169.250
169.600 National Emergency Training Center
169.875 Simplex; Regional EOC Net 3
170.200 Federal Disaster Net
170.425 Repeater Input to 168.075
170.450 Repeater Input to 168.100
170.975 Repeater Input to 168.700
173.1875 Repeater Input to 167.975
409.125
453.525
** All regions, for use in actual disasters only
The above frequencies were copied from
http://www.survivalring.org/cd-femafreqs.htm I have most but not all of these frequencies programmed, only what my scanner will permit of course.
For the Red Cross I have the following frequencies:
46.0000
47.4200
47.5200
47.4600
47.5400
47.5000
47.6600
These frequencies are used in just about every state, however there are alot more that are shared with other local agencies. You will have to look up your individual state and see if any others are in use. I do not have PL codes for any of these as my scanner does not support this feature. If you like I can always create an XL spreadsheet of all the frequencies that are in use. Also, both FEMA and the Red Cross have alot of HF frequencies, but those of course can not be heard with any ordinary scanning receiver.
I do not monitor these frequencies on a daily basis, but being only a stones throw from ground zero, I felt these were important in the event of another emergency such as on 9/11.
Hope this helps, keep on scanning!!
kar2n101
