I might have missed it in the thread but did anyone mention the Uniden UBC30XLT Radio Scanner?
Is it available here in USA?
I want one!! Too bad I don't see it here in the states. Quite frankly, I'd probably use it more than my Icom R6 for quick airband duties.
From the specs, even though it is a dual-conversion receiver, the first IF is 51.75 mhz -- a welcome relief from the usual 10.7 mhz in units at this price range - although not going above VHF Hi makes using 51.75 practical as the first IF.
I would hope that being surrounded by the FM broadcast band, and also VHF HI, that Uniden would put in some decent bandpass filters separating each band - I'll bet they do, but I would love to test it. It would be a shame if they ran a bandpass from 88-174 mhz. Without specs on the bandpass, I'd have to do some brute-force testing.
The 8.33khz spacing option for airband is nice for areas that use it. There is no dc-input, and it runs on three AA's - they say you can use rechargeables, but I see no way to tell the UBC30 how to tell the difference between alkaline and nimh rechargeable so that you don't have a premature battery warning. Switch inside the battery door? Not clear from just the manual.
The only thing that kind of sticks out is the 25 channels per second scan/search rate. I definitely wouldn't use the search for too long and hope to find things - definitely go to airnav.com and resources here to find frequencies faster.
Having a user-selectable delay time of anywhere from 0-5 seconds (appears to be a global setting) is interesting in this price range. That might really be useful if you have some very laid-back comms going on - although I think that might be a consideration if you were to load up the scanner fully, and with only 25cps scan rate, miss a transmission by the time it came back around - possibly why such a long delay is available as an option. Nice of them to offer that instead of just the standard 2 secs delay or zero.
If one were to totally load up the memories for airband use, I'd definitely be busy locking out freqs that aren't in my area at the time, to make the scan go faster - and even possibly not using any delay at all. Having only one memory bank for airband could be a bit daunting for heavy users.
Still, I'd LOVE to have one in my collection!
