scanner feed
pinellasfirefighter
Banned
seminole fl
i am no longer using shoutcast. i just bought the butel arc eazy-stream. this program has no delay and shows tex tags of the channels that you are listening to.. in order for you to listen to my feed you will have to go to http://www.butelsoftware.com/ download the arc eazy stream client its free..
after you get that install which only takes a second enter my addy.
pinellasfirerescue.no-ip.org
then make sure the ports are set on
audio port 8100
data port 8101
happy listening.....
