The Pro-97 may be a nice scanner, but I see two immediate drawbacks. First, I haven't heard of any software available for the 97 yet, so it isn't computer-programable
at this time. Second, it's a handheld scanner. From personal experience, I can tell you that a handheld just doesn't cut it when chasing. The audio is not as good as a mobile, the display is too small, and the radio will come adrift at the worst possible moment. I know you can get an amplified speaker, but by the time you mount the speaker, and securely mount your handheld, you might as well have gotten a mobile in the first place.
That is why, for all the above reasons, I have a 780 in my truck, and may add a second one. Many other chasers I know also use Unidens. I tried it with a 2067 for several years, and the dinky display just doesn't cut it. That also eliminates the current crop of RS/GRE mobiles, they still use the tiny display from the handhelds.
I recommend to most new scanner purchasers that they get a good handheld for their first scanner, but in this case, mobile units rule!
As for the request for spotter freqs from need2speed, look here for spotter freqs:
http://www.caps.ou.edu/~kbrews/spotfreq/
And Danny, I'm not sure what you point is, I was addressing Cobra Commander's contention that the 97 is preprogrammed with stormspotting freqs, not whether or not dwunl68 had the freqs he needed for local area reception. Let me emphasize
local area, I've seen chases on an active day that spanned three states. Hence the need for a good freq reference and a computer-programmable scanner.
Mark S.
