RIDERFAN34
Yes i just got a whistler digital 1065 scanner and i was wondering if anyone could help me im looking for any info on belmont county ohio scanner frequencies so i could program it into my scanner
While it is much quicker, as well as more accurate, to program a system using software, it can be done manually through the keyboard.I understand that belmont county law enforcement is encrypted and cant be monitered but how can i montor belmont county fire ems public service on my digital scanner cause im not fimilar with downloading software is there a way i can manually program the frequency they use into my 1065 digital scanner cause i tried getting the frequency numbers off here but it says they use the 700 ohio marcs system and the project 25 phase I system but im looking to see how to program the system they use into my scanner like the 853.700 mhz it says for belmont county on the 800 mhz frequency
For Belmont County, Ohio, the Belmont system is a P25 Standard (Phase I) system. Not sure where you are seeing that it is not, because it says exactly that (Project 25) in the system details:Yes Im looking to program belmont county ohio scanner frequency into my scanner and i was on here a few days ago and someone sent me a video on how to program the project 25 phase I into my scanner but im kind of confused as to what i should put cause i found this where it says apco25 caie for belmont county which it says its not a project 25 phase I system and it wants me to place it under motorola 800 900 mhz frequency so when programing this county into my scanner should i put it under trunked system project 25 auto or voice or should i put it under the 800 mhz trunked frequency and for my frequencies it says simulcast for belmont county ohio so when programing it should i use the ohio marcs frequencies for belmont county or should i use the 800 mhz frequency its listing for belmont county.
P25 AutoOk so when I go to put this system into my digital scanner which p25 system do I use to program Belmont county ohio cause I have p25 auto p25 manual ltr mot 800/900 mot vhf/uhf edacs std edacs narow listed as my trunking systems
