OsloViking1975
I'm not to sure youre scanner will only pull the amps it needs it's the volts tha kill you.
Cool! Now the next step for the electronics tinkerer would be to open the radio and find the part that's making noise. Since there is 110VAC inside this should be done with proper precautions to not get shocked. Transformers are classic parts for vibration noise but it could be something else.Hey guys it works perfect, no noise at all. So yeah, it was the built in power...so happy it was not the scanner.
Thank you very much for your help, you are great.
Hopefully this thread will help somebody else if they encounter the same problem.
Mike
You are right, that's the next step for me. I will see what I can do about it.Cool! Now the next step for the electronics tinkerer would be to open the radio and find the part that's making noise. Since there is 110VAC inside this should be done with proper precautions to not get shocked. Transformers are classic parts for vibration noise but it could be something else.
Anyway, now you know.
Since the noise is likely a mechanical vibration, a classic fix is to "goop" the part in some non-conductive material that looks like RTV (but isn't).You are right, that's the next step for me. I will see what I can do about it.
I believe it might be an F adapter.Does anyone know what size radioshack "adaptaplug" the 2006 takes??
That would do it? That's sounds easy. What type of material are you referring to? Something that looks like RTV but isn't, for example?Since the noise is likely a mechanical vibration, a classic fix is to "goop" the part in some non-conductive material that looks like RTV (but isn't).
I had a BEARCAT scanner that had a HUM like that. It had a built-in power supply and it was the transformer. I tried tightening the mounts and all kinds of things but it just kept coming back. Have you considered not using the built in power and running it on 12 v? Had many problems with scanners over the years..Try a BEARCAT that over time lost it's programming. lol Was the 1st BEARCAT that they got rid of the 9v battery for memory and it would over time lose programming and you'd notice "Hey, why am I not hearing anything on the scanner?" Uniden never could fix that scanner, I gave it away! But I digress Good luck and tey a 12v power supply assuning that scanner can go mobile.PS:actually I find the noise annoying now(off or on, it does not matter), and I am wondering why i did not notice it before. I was playing with antennas yesterday, but I also played with some antennas on my PRO-164 and it is working fine.
