jaymatt1978
Ok I have been using the Scanner Master four scanner power supply and it works great EXCEPT the power plug ALWAYS falls out of the power strip causing an unexpected loss of power which I heard isn't good for the SDS200. If you look closely there's a lip between the plug which caused the two prongs that go into the outlet the be very loose. I don't really know the ins and out of circuitry but I consider this a MAJOR design flaw, especially since turning the SDS200 on and off rapidly can damage the memory . I wish Scanner Mater used the same plug as Uniden, the one that goes horizontal inside of vertical. Anyone else has this problem???
