cpsTN
I live in the ZIP Code 37129 and VERY near 37167. I am wondering if there are any other scanner "people" who live within the ZIP Codes of 37086, 37129, 37130 or 37167?
Charles
Smyrna, TN
Charles
Smyrna, TN
Are you actually in Williamson Co. or farther east, into Rutherford Co.? By the way, how do you create a signature?
Charles
Smyrna, TN
You mean avatar? Its in the user control panel under the tab edit avatar. I am in eastern Williamson county.
I live in Nashville (37211) but am in Smyrna quite a bit. Can't wait to get down there and check out their new airwaves.
You are welcome for the freqs. Sorry, I forget about the area in which you live. I would like to get hold of someone else who has Smyrna's Trunked freqs so I can compare mine to see if I have mine set up correctly. Of the 5 freqs, I am receiving on only 2 of them: 851.40000 and 852.03750. On these 2 freqs, I am hearing Police, Fire, EMS, and aparently one of the utility depts. 852.03750 is much more active.
Charles Sands
Smyrna, TN
I have a GRE 500 and a Uniden 396XT, and I put in all the 10 frequencies shown in the database, and both scanners are receiving the system just fine. However, I did have to enter the trunking tables data. If you have a programming cable, and know how, you might want to download the Smyrna system from the RadioReference database into your scanner. That would probably populate the trunking tables for you automatically, but, if you can't do that, you might be able to enter these manually.
I am still trying to find my way around the RR site. Can you tell how to get there or post a link? Thank You.
Charles,
Are you using Win 500? If so open File, Import Web then conv or trunked and it will open a page for you to place your RR login info then has drop down menus to get to the right database where you click and choose. The only complaint I have is that the tags are sometime just short of useless but it sure saves time entering data.
Charles,
Charles,
If you don;t link up let me know and I can run over sometime this weekend with my laptop and cable.
Doc
