Scanner Power
BRFD-118
I bought a Uniden BCT8 scanner for Christmas. I began to read the manual and saw that it said you should, "turn the scanner OFF before disconnecting power." I plan to mount the unit in my Toyota Tacoma. I would like it to where i can just turn the vehicle on and the scanner come on. Is their a special power wire that i need to get or a certain way i need to hook it up?
Bucko
Marietta, Ohio
You could hook it to your Accessory switch ( Ignition switch feed for your stereo at fuse block) but doing this could mess up the programming of your scanner when you start your vehicle.
n0nhp
Grand Junction
Some of this is a manufacturer being over careful, the early microprocessor equipment reacted very poorly to low voltage and voltage spikes such as you get during starting. Granted I am a dinosaur and have had programmable scanners in my vehicles since the Bearcat 101 in the early 70s but I also like to err on the side of caution. Both my vehicles have a SPST switch mounted in the dashboard. All the auxillary gear goes through that switch. After the engine starts the switch is thrown, before the engine is shut off, the switch is thrown. If I am sitting in the car waiting for something to happen I can just flip the switch and have my entertainment without every buzzer and warning light on the dash telling me that I am abusing the vehicle.
Simple easy and becomes habit.
I also went down to the local two-way shop and got a GE fuse block to run the supply wire through. If I have to jump start my own or another vehicle from my vehicle I pop the cap off the fuse block, pulling the fuse and avoiding having the remotest chance of spiking my radios, It will save many times the cost of the fuse and block.
Bruce
BRFD-118
Ok thanks for the replies, but i was on Kenwoods website and i saw a wire called a Ignition sense wire. What is this and would it help solve this problem.
n8emr
Most modern vehicle do have a "engine running" line that is used to control the A/V items.. Check your stereo deck wiring and see if you have one.
If your refering to the kenwood 2 way radio ignition sense line then no thats not what you want.
BRFD-118
well it sounds like the easiest thing to do is to just use the on/off switch on the unit. lol
