I am trying to figure out how to use a scanner with a vhf radio on the same antenna. Currently we are using the scanner with the vhf radio, however the antenna is immediately hooked into a duplexer and the VHF side going to the VHF radio and the UHF side going to the scanner. The problem is their is only one antenna and we want the scanner to receive not just UHF. Is there a way to put a splitter prior to the duplexer and have that one line run to the scanner?
I am aware this could blow the scanner out if using the VHF radio to transmit. Is their some type of device I could put on the line going to the scanner to protect it from the power from the VHF radio going into the scanner? if it matters it is all Type-N connectors and the line coming off the UHF side of the duplexer is using an adaptor to convert it to BNC.
