KC_zero_DSU
I have a BCD996P2 and not sure what I did or how I did it but when I try to go back out of menu to scanning the p25 system I had set up now the screen alternately flashes
'Close Call' 'Channels Found' and shows the control channel frequency for my system and a NAC. None of my group quick key numbers were showing across the bottom. Nothing I tried would get it back to showing the county name I programmed on first line, scrolling 'ID Scan' on second line, Frequency on third line etc... I panicked and did a reset then re-uploaded my system with FreeScan. But now every thing looks the same as it did when things were working right but I'm not hearing anything, maybe it's because it's almost midnight but even then I usually heard Highway Patrol checking in. I'd like to know how to fix the flashing 'Close Call' 'Channels Found Issue' in case it happens again. This is the biggest pain in the ass scanner to program and operate I've ever owned in my life. And the manual is not much help. If you can help thanks in advance.
