Scanner Suggestion?
Okie1960
Duncan, Okla (Stephens Cty)
Any suggestions for what scanner for the Lawton/Ft Sill/Duncan area?? I know the local police/sheriff are still the old style, but OHP has gone up to the 800 mhz so I miss most of their traffic. A friend has a Uniden Bearcat BCT8 but says his reception of OHP is poor. Looking over at the other sections it partly looks like I need digital for OHP but not sure. Thanks! OK
Freqed
I'm just a listener
Broken Arrow
As far as OHP not digital now but will be, so something that will recieve digital would be a plus for you. Not sure about the others.
N5TWB
Sand Springs OK
Lawton & Commanche County are both on OKWIN 800 but, as you noted, Duncan and Stephens County remain on VHF-Hi. Ft.Sill is running P25 on OKWIN.
Take all that together and I'd say you need a top-line, digital-capable scanner if you wish to monitor everything in the area. I'm partial to Uniden but that's just me and you should also check out possibilities from others.
plaws
E Hawkesbury Twp, ON
Get a BCT15 via eBay. That model has been replaced by the BCT15X so the older ones should be well under $200. It trunks but does not do digital. You don't need a P25 digital scanner for OHP yet, so you can get away with analog, maybe for several years.
Get the Freescan software and, for $15, get a 6-month subscription to RadioReference. Freescan will allow you to import OHP (and anything else) directly to the software. Then you can load it into the scanner.
HogDriver
Blackford Co. Indiana
Pro 97/106. I have one of each and so when I'm away from my vehicle I can still listen and they are programmed the same. They do trunking and are digital. You can usually find them on sale in a six-month period at Radio Shack. Fort Sill is digital so you might as well not limit yourself so just go ahead and go digital!
