Scanner that can be programmed via serial for remote feed
radef
I've been running a feed for almost a year with an RTL SDR dongle & Raspberry Pi. The concept is nice, but the audio quality is terrible & I haven't been able to get results like a dedicated receiver can provide.
I'm looking for options for a remote controlled scanner that I can tie into a Raspberry Pi and be able to add/remove channels via a serial connection to the scanner (through a serial terminal session...no custom software is my preference). I need this because the Pi is not in a location that I can access.
I've seen some Uniden scanners have serial protocol info online. What about the GRE/Whistlers? Here's my list of requirements:
channel add (set frequency and modulation)
channel remove
channel skip
scan start
manual channel change (for instance if I want to listen to one freq)
scan stop
Anyone else with a similar setup have some insight? I don't mind if it's a current model or no longer in production. I only need analog conventional FM (and AM would be nice, too). No trunking, no P25, etc.
nated1992
Asheville NC
channel remove
channel skip
scan start
scan stop
Pretty much any of your new scanners do this, My pro 652 has a computer interface.
HOWEVER... none of this is built on Linux so running it on the pi isn't going to be possible the way your wanting.
larryka
I wrote a Node.js based WebRTC webapp that remotely controls my Pro-106. It should run on a Pi, but I haven't tried it yet. I send keypresses and screen updates via a websocket. The audio is fed via Asterisk with Opus for 500ms or so of audio latency.
I'd be happy to chat about how I did it.
- Lawrence
larryka
Here's a screenshot from my webapp. Please forgive the misaligned keypad.
wyShack
Campbell County, Wyoming
Look for an old Pro-2052. 1000 channels and came standard with a RS232 port on the rear panel. the Manual explained all the commands for a terminal connected to the port (straight ASCII so it would be pretty much universal). Old fashioned by today's standards-the major drawback would be finding a couple so you have a backup. The 22052 is not set up for rebanding and may not cover all the frequencies you are interested in.
There are other model scanners that had serial I/O -you may want to check the Wiki or otherwise do some research.
have fun
radef
- Lawrence
Very slick! I just ordered a BCT-15X to play around with...I'm going to give that a whirl for now.
radef
have fun
Thanks, good info! Seems to me I had a 2052 a ways back...even think I have a service manual laying around for it! Do they have a narrow band option...or just need to crank up the volume? Are the volume and squelch adjustable via the serial port?
I did pick up a BCT-15X with some hopes of tinkering around with it.
PACNWDude
Nice application.
I use a Unden BCT-15 (Not the newer X version) and bcTool. It is pretty nice controlling and logging the scanner via the computer. Then it is a small step beyond to stream that feed.
larryka
Kudos! That's awesome!
Thanks. If the Uniden DMA protocol is documented (I haven't looked), you could probably do something similar. Just write a small bridge between the websocket and the serial interface to the scanner.
