scanner trouble
deppler
I just got a bcd996xt scanner and I am trying to hook it to my computer for some truncking numbers and I am using a usb cord from the computer to the little port on the front of the scanner I bought a cable and a converter plug in to make it work don't know if that is why it cant find my scanner any help thanks
deppler
No I bought the adapter from radio shack and the only cd that came with the scanner is the owner Manuel
N8IAA
Fortunately, GA
If you are using the RS cable, and plugging the stereo plug into the headphone, it won't work. If you are using the cable that came with the scanner, you will need a DB-9 connection on the PC. If you bought the Uniden USB-1 cable, you will just need to plug it into a USB port on the computer.
As posted, the cable that came with the software from RS only works on scanners like the Pro-106/197.
This is why the computer doesn't recognize the scanner.
Larry
