Scanner type info needed.
mfolta1
tulsa okla.
Could someone tell me which scanner I need to hear the I calls(private calls) id 70000. Thanks.
richster
Regina, Sask.
Well I can do that. :D
First of all Radio Shack is out of the question. This is real sad too, beacuse the pro96 is a very good scanner.
Any Uniden Bearcat scanner that has Trunktracker III technology or later. If this system your listening to is digital, the BC296D is a good portable radio that will track I-calls. If not, then I suggest you wait for the BC246T that is coming out next month. It will be much cheaper than a digital capable radio, and has some new radical features like Close Call, and Dynamic Memory.
Also if this system is 9600 baud, your SOL sad to say. :cry:
Unfortunately the new Unidens will only follow I-Calls on 3600 baud Motorola systems.
I might be wrong on this, but I do think they will follow I-Calls on a 9600 baud EDACS system. I can't say for sure, not until I get my 246T and test it out myself.
Regards,
Richster.
mfolta1
tulsa okla.
thanks, i was refering to the tulsa system or state system as it is. Let me know if anyone here is able to hear tulsa ohp i calls(private calls) and if so what scanner are they using? thanks again..........
peterjmag
Oklahoma City, OK
Folta,
I am using a Bearcat 780xlt to hear private and I-calls. Not only do I hear OHP use them, I hear Sapulpa PD, and Life Flight gives patient reports through them. Owasso also uses them on their system. Broken Arrow uses them a lot on their system as well.
P.J. Maguire
DaveIN
Founders Curmudgen
West Michigan
I did a quick search and did not see my answer, but do Motorola 9600 systems even have individual calls (i-calls) :?:
