Watch out unplugging the usb while it's on. Depends on what the scanner is doing (writing to the SD card for example) it can corrupt the card. I have my plugged in on my work bench and a few times I turn the bench off forgetting to turn the scanner off. Most times nothing happens, but a few times the card was toast or I lost a couple of objects.I also notice that after applying this update, it's no longer possible to unplug the USB cable (while it is charging) without the TRX-1 shutting off. This is very annoying.
There is no problem when I initial plug it into a USB charger / adapter, however when you unplug it, the unit just shuts off (it doesn't appear to perform a clean shutdown).
This occurs with a USB adapter (Maxboost Wall adapter) and my laptop USB ports.
Sent from my SAMSUNG-SM-G870A using Tapatalk
