scanner upgrade suggestions
Mirlyn
ICT
I'm still running a Pro-92 and a Pro-2067 for Sedgwick/Wichita public service monitoring which work great, but I'm looking to upgrade and should take the new system into consideration. I've read a little about KSICS, and it looks like it'll eventually make my equipment outdated (betting these are analog-only receivers, and the new system looks exclusively digital).
Is the BCD996XT a safe bet on the new system? Or should I wait for a newer scanner to be available closer to the implementation of KSICS around here?
Thanks!
dgruver911
Newton, KS
Closer? KSICS is here....all KHP Wichita traffic is P25, Butler and Reno Counties will be by the end of the year, Sedgwick County plans to be in a couple of years or so. So you may as well start looking now. I'll let someone else make recommendations; I have a Pro197 and a GRE500. They do OK but I can't believe there isn't soemthing better out there. I seem to miss a lot of traffic especially on VHF.
Mirlyn
ICT
Yeah, closer as in closer to when SG dumps the current trunking system. Like you said, I'm thinking I have another year or two if something better is being anticipated.
Gadgetman728
outside wichita, Kansas
I agree with dgruver - A digital radio will be needed for the modern, up to date counties, but a decent analog radio for the conventional channels seems prudent. I have a 500 that moves around the house with me, but I have an old Pro-2006, on a ledge in the living room programmed with the the local VHF channels, it hears GREAT. The 500 hardly ever stops on VHF channels, because the Sedgwick Co. trunking system stays pretty busy. I haven't used a Uniden scanner for a long time ( i have several on a shelf in my library , but they are fine scanners. I'm thinking about getting a 396 just to play with the programming. Either brand of radio is fine, things are going digital, but Andy & Barney still talk on their conventional radios.
eaf1956
Evansville, IN
Uniden
Thanks!
I'd wait and see what UNIDEN annouces during their OPEN HOUSE....
jereck_99
Pratt ks
i would go with a Radio Shack Digtal scanner it is easy to program and easy to change the program in
